Activity › Forums › Adobe After Effects Expressions › Subtitles into afterFX. Is it possible?
Posted by Daniel Martinez on September 24, 2005 at 10:32 pmIs it possible to import subtitles into after FX?
Like the Adobe Encore DVD text format?
Or PAC, STL or EBU files – or any other format?Is there a PlugIn that does it??
Thehardmenpath replied 20 years, 12 months ago 3 Members · 6 Replies -
Dan Ebberts
September 24, 2005 at 11:11 pmYou should be able to import and parse a text file in one of those formats with a script. It would probably work best if you already had a blank text layer all set up with your font, size, color, positioning and justification choices.
The script wouldn’t be trivial, but it shouldn’t be too tough either.
Dan
Daniel Martinez
September 25, 2005 at 5:24 amIn what langauge should i write the script?
Is it expresions? -
Dan Ebberts
September 25, 2005 at 5:57 amNo, expressions can’t do file I/O. It would need to be in AE’s scripting language, which is based on JavaScript. You need AE 6.5 Pro though.
Dan
Daniel Martinez
September 25, 2005 at 8:25 amI know I can do this, because I’m pretty good at programing – but
can you with this AE script define when a title should show? I mean does the AE script provide any means for controling how the imported text should behave in relation to the compositions timecode?Because if I was to do it with expresions I would have imported subtitle file, wich format is:
subtitle# starting_timecode ending_timecode subtitle(this is the actual text)
And have all the text with codes in one layer. Then I would rund the text throug my expretion and if the playhead eaquals a given subtitle# IN/OUT time span, it would parse that subtitle to a variable which again is read from another text layer with the expresion to turn the opacity to 100 if the variable is anything but empty.
Does it make sence?
Dan Ebberts
September 25, 2005 at 3:43 pmWith scripting, you would use the setValueAtTime() method to create keyframes for the text layer’s Source Text property – either setting the value to the subtitle text at the start time or to blank at the end time. Something like that.
Dan
Thehardmenpath
September 25, 2005 at 4:52 pmCheck this out, it probably will spare you a lot of time:
https://www.aenhancers.com/viewtopic.php?t=247
