Activity Forums VEGAS Pro Subtitles in text format import into Vegas?
  • Subtitles in text format import into Vegas?
    Posted by Vsv on April 14, 2005 at 1:19 pm
    I have subtitles with timecodes in *.srt text format. How i can import subtitles into Vegas and place the text on timeline according to timecodes? Any suggestion or script, please.
    Vsv replied 21 years, 4 months ago 4 Members · 10 Replies
  • 10 Replies
  • Edward Troxel
    April 14, 2005 at 1:23 pm
    Are you wanting to place a text generated media containing the specified text at the specified location/lengths? If yes, it can’t be done via a script.
    A script could read the file, create text generated medias of the proper length at the proper location, and pick a preset for the text box. The script CANNOT change the text.
    A script could create regions and name those regions with the subtitle names.
    Just wondering what the ultimate goal is.
    Edward Troxel
    JETDV Scripts
  • Vsv
    April 14, 2005 at 4:00 pm
    Edward
    Thank you, Edward, for nice explaining my wishes:) This script exist and free?
    Subtitles script look like this:
    00:00:34:08 00:00:37:20
    Text text text
    00:00:39:06 00:00:42:08
    Text text text
    This need for making translation (record voice over) in same time when watching video on preview monitor.
  • Edward Troxel
    April 14, 2005 at 5:09 pm
    As I said, it can NOT be done via a script. A script cannot change the text in a generated media.
    Edward Troxel
    JETDV Scripts
  • Rob Mack
    April 15, 2005 at 5:19 am
    DVD Architect will import plain text to a subtitile track. Supposedly, it’ll also import *.sub files but it seems that DVDA wan’t a very wierd *.sub format. I couldn’t get it to play well with others.
    There is a free script at the VAST site that will import a sub file into Vegas and make markers out of it. That may or may not help. There is also another script there that will export those markers as a *.sub file but DVDa couldn’t read the file. Maybe you don’t need that though, but just need a way to generate text events in Vegas based on the file.
    There’s a tool called Subtitle Workshop that is free and may at least help you convert *.srt files to *.sub files.
    Rob Mack
  • Vsv
    April 15, 2005 at 7:46 am
    Thanks, Edward. My mistake.
  • Vsv
    April 15, 2005 at 7:54 am
    rob mack
    Thank you for help. My final solution is embeded subtitles into avi done by VirtualDub.
  • Rob Mack
    April 15, 2005 at 5:03 pm
    Ahhh,
    I’ve been ignoring Virtualdub. This would be a nice solution if you can then put the AVI onto the timeline and record the translation on another track.
    Rob
  • Fotis Vassis
    April 15, 2005 at 5:04 pm
    1)Download subtlitle workshop and convert the subs to ssa format (substation alpha)
    2) Get the subtitler plugin for Virtualdub (from Virtualdub site)and place it in Virtualdub plugin folder
    3) Get the Satish pluginpac for Vegas(the old one with the adapter) and use the adapter in Vegas to load the virtualdub subtitler. It’s very easy and I have used it many times.
    It’s a bit tricky though, there is a manual how to do it in Satish’s site
  • Rob Mack
    April 15, 2005 at 5:16 pm
    Rob Mack
  • Vsv
    April 18, 2005 at 3:15 pm
    Fotis_Greece
    Super! Thank you!
