Activity Forums Apple Final Cut Pro Legacy Subtitles in FCP & DVD SP
  • Subtitles in FCP & DVD SP
    Posted by John Watts on January 21, 2009 at 8:24 pm
    Ok folks, here it goes:
    I often get requests to add subtitles to corporate films and burn them to DVD, which is easy enough. But I don’t think I am working in the most efficient way. I use Boris Title 3D in Final Cut Pro and create a quicktime with the subtitles on, which i then encode in compressor and import in to DVD SP.
    The problem with this method is that if I want to make a DVD where the viewer has the option of turning the subtitles on or off, I have to create two quicktimes, one with, one without subtitles. Which can take up too much disk space.
    I am sure there is a way to export the subtitles that I have created in FCP, to DVD SP, but I just don’t know how. My aim is to have a button at the bottom of the DVD menu which turns on/off the subtitles.
    I do not want to use DVD SP to create the subtitles as I find the Boris 3D tool creates a higher quality looking subtitle.
    If anybody could explain their methods I would greatly appreciate it. Also If I need to buy some additional software, please feel free to recommend some.
    Thanks in advance.
    John
    Nicholas Bierzonski replied 17 years, 7 months ago 3 Members · 3 Replies
  • Nicholas Bierzonski
    January 21, 2009 at 8:41 pm
    This is possible if you export your titles as a xml and run them through a program such as Spherico Title exchange. This program converts your files into a subtitle stream that DVDSP can read. This will allow you to use one movie in DVDSP and the user can turn the subtitles on and off.
    -Nicholas Bierzonski
    Senior Editor/DVD Author/Java Boy
    http://www.finalfocusvideo.com
  • Andreas Kiel
    January 21, 2009 at 11:31 pm
    But TitleExchange won’t work which Boris – and no other similar XML application will work with it as well.
    The TitleExchange demo comes with a free but professional subtitle generator called TextUp which may/will be helpful when doing subtitles.
    Regards
    Andreas
    Spherico
    https://www.spherico.com/filmtools
    January 22, 2009 at 1:16 pm
    Good Point Andreas. Hello by the way!
    I use TextUpPro myself while subtitling. The title safe function speeds up subtitling considerably. I highly recommend it.
