Activity Forums Apple Final Cut Pro Legacy Subtitles in DCP
  • Subtitles in DCP
    Posted by George Roberson on July 22, 2014 at 3:19 pm
    If I need subtitles in DCP files, what are the options?
    Should I put titles in the FCP before exporting to make DCP files? That way the video is coupled with subtitles all the time?
    Or there is a way to make subtitles files in DCP? Export video from FCP without subtitle? that way maybe there will be choices to have a few different language subtitles that can couple with Non-subtitle video?
    Any inputs will be appreciated!
    George
    Michael Gissing replied 12 years, 1 month ago 2 Members · 3 Replies
  • Michael Gissing
    July 23, 2014 at 1:11 am
    The DCP spec allows for subtitle data files to be added to a clean picture in the DCP. I don’t know how you would produce the subtitle file to add using FCP however.
    I have only made one subtitled DCP (using OpenDCP software) and noted that there was that capability but the master file had baked in English subtitles.
  • George Roberson
    July 23, 2014 at 4:00 am
    Thanks for the reply. Was it easy to use easy DCP? How long is your movie?
    So you placed the subtitle in FCP before exporting to make the DCP files?
  • Michael Gissing
    July 24, 2014 at 8:09 am
    Open DCP is pretty easy plus I found some youtube clips that helped explain the workflow.
    Yes subtitles were put on in FCP and baked into the master ProRes file. The program was 85 minutes – a feature doco
