Activity Forums DVD Authoring subtitles embedded in Quicktime file
  • subtitles embedded in Quicktime file
    Posted by Josh Snider on April 3, 2008 at 7:07 pm
    Hi, I’ve been working with subtitling for the past year, but I’ve always produced DVD’s as my final product.
    I have a new client that wants the subtitles embedded in a Quicktime file. I usually use .stl files (Spruce Technologies) in conjunction with DVD Studio Pro. But the only way I can think of embedding the subtitles into a Quicktime file is to enter them into text layers in Final Cut Pro. This would be slow and arduous.
    Any other methods?
    Would Annotation Edit be able to handle this?
    Thanks, Josh
    Brent Robertson replied 18 years, 4 months ago 4 Members · 6 Replies
  • Noah Kadner
    April 4, 2008 at 6:59 am
    Burn em in- not much else you can do.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
    https://www.callboxlive.com
  • Josh Snider
    April 4, 2008 at 2:12 pm
    This might sound stupid, but what do you mean by ‘burn them in’?
    Josh
  • Noah Kadner
    April 4, 2008 at 2:41 pm
    Make them as titles in FCP- and make sure to charge the client for your time.
    Noah
  • Josh Snider
    April 4, 2008 at 10:53 pm
    Unfortunately my boss charged by the job on this, so I don’t have the option of charging by the hour.
    I think there are options other than long-hand in FCP. In fact, I was able to do everything in Quicktime’s Text Tracker, except for that its text outlining function doesn’t work properly. Since I need my subtitles outlined, it was a no-go. But I can give you the method for that if u’re interested.
    J
  • John Thames
    April 5, 2008 at 7:31 pm
    Check out belle nuit. https://www.belle-nuit.com/
    i believe you can import a stl file and export a xml file which can be imported in FCP.
    An other option is:
    make a dvd with dvdstudio pro and use your stl file. After you build your dvd you can use a dvdripping software package like handbreak to rip yor own movie again+the subtitle track. It isn;t the most beautiful solution but it can be used as a last resort. 😉
  • Brent Robertson
    May 16, 2008 at 9:45 pm
    https://www.automaticsync.com/caption/howto_vids.htm shows you how to do this in QT Pro with a QT.TXT file.
    You can get back both QT.TXT files (along with SCC and STL) when you submit your media and transcript to CaptionSync (this is an online captioning service).
