Activity › Forums › Adobe Encore DVD › Subtitles and nametags
  • Subtitles and nametags
    Posted by Lotte De man on February 4, 2013 at 2:44 pm
    Hi There,
    I have got a challenge and I hope someone can help me.
    I’m making a dvd with 5 short documentaries. I have them subtitled.
    I imported 2 versions of each film in my encore project. One with Dutch nametags, filmname and credits and the other one with the same titles in English.
    In encore I imported all the films and also imported their subs and everything works fine. But because I have now 10 short documentaries in my project (5 dutch and 5 english) it doesn’t fit on a dvd. The 10th film doesn’t fit on the dvd.
    So here’s my question. I thought, if I import each documentary without any titles in Encore. Maybe I can make the nametags, credits etc in the two different languages in encore next to/or included in my subtitlestrack?
    Has anyone got any experience with this?
    I hope so!
    Thanks Lotte
    Daniel Ludwig replied 13 years, 7 months ago 2 Members · 5 Replies
  • Daniel Ludwig
    February 5, 2013 at 2:25 pm
    Lotte,
    to use subtitle for this is just a work-arround, as subtitle have no anti-aliasing and doesn´t look as good as when you create the typo within your NLE.
    what is the whole duration of all 10 films? did you try authoring DVD-5 or DVD-9?
    what bitrate do you use for encoding? audio have been transcoded to dolby AC3?
    all these could help you to have as much space as necessary to get all 10 films on your disc.
    cheers
    danny
  • Lotte De man
    February 6, 2013 at 2:17 pm
    Hi Daniel,
    Thanks for your reply!
    I was already thinking about the dvd-9. But only if there is no other solution.
    The 10 films are all together are about 155 minutes.
    There should be a way to fit them all on the dvd.
    Maybe with an other compression in Adobe Encore.
    I now used for video
    and for audio
    Any comments?
    Thanks Lotte
  • Daniel Ludwig
    February 6, 2013 at 2:45 pm
    hey lotte,
    if you have 155min video and you use AC3-audio, you could easily use an average of 6.5MBit and use a VBR up to 8Mbit (peak rate), so you wont overfill your DVD-9.
    if you would like to stay at DVD-5 you need to have an average rate at approx 3.5MBit – that´s no good! I would advice to use DVD-9.
    cheers
    danny
  • Lotte De man
    March 1, 2013 at 9:14 am
    Hy Danny,
    Thank you, for your replies!
    With the final versions of the films it just fit.
    But only if I use the automatic transcoding settings. before I used dvpal with widescreen and progressive scan.
    Do you think this automatic setting will make it fit on the dvd?
    cheers, Lotte
  • Daniel Ludwig
    March 1, 2013 at 11:33 am
    Lotte,
    if you used the bitrate-settings that I calculated – your content should not overfill your final disc. this could only be possible if there is some additinal content on it that I didn´t know.
    your previous setting (where you´ve taken these screenshots from) had higher bitrates as you could use – as you could see they had 4Mbit/s, but the bitbudget calculated 3.5MBit/s possible instead.
    why you used progressive encoding? and by the way PAL-material has no pan&scan, you could only use widescreen.
    cheers
    danny
