Activity Forums Apple Final Cut Pro Legacy subtitle text properties
  • subtitle text properties
    Posted by Himanshu Bhatnagar on August 16, 2011 at 6:57 pm
    Hello,
    I’m currently editing a 1080p footage. Now, when I try to add some subtitles to the video and drag the text to the time line it asks me to render.
    This is probably because the subtitles are in 720p or some settings other than my footage.
    How do I change the text settings so that I don’t have to render it again and again?
    Thanks in advance.
    ~Himanshu Bhatnagar
    Himanshu Bhatnagar replied 15 years, 1 month ago 3 Members · 6 Replies
  • Jerry Hofmann
    August 16, 2011 at 7:18 pm
    There are no format settings for the titles… they conform to whatever the sequence setting is the moment you place them there.
    If you have material under them that needed rendering (filters, stills etc), you’ll need to re render. (normal)
    If you have turned off “Unlimited playback” from the RT pop up menu in the Timeline Window, you’ll need to render too. Faster computers need to render less BTW.
    But from what you’ve posted, it’s hard to tell the exact reason why you’re having to render, but it’s not a setting to change there except for that RT menu item.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Himanshu Bhatnagar
    August 16, 2011 at 8:17 pm
    Thanks for the quick response.
    I checked at the RT pop up in time line. Its giving me two options
    1. use play back setting (this one is checked)
    2. Full quality.
    What should I do?
    thanks.
  • Jerry Hofmann
    August 16, 2011 at 8:20 pm
    Post your sequence’s settings.
    Jerry
    Current DVD:
    August 17, 2011 at 7:20 am
    Frame size 1080; aspect ratio – hdtv1080i(16:9)
    PAR – square
    field dominance – upper odd
    editing timebase – 25
    compressor – h.264
    Himanshu
  • Pradip Patil
    August 17, 2011 at 1:16 pm
    Himanshu it’s H.264 that’s causing trouble.
    You never edit in H.264, Is your source footage shot on DSLR camera?
    You will need to convert it to prores. This is a regular topic here. Please serach for it.
    Pradip Patil
    Mumbai,India
    August 17, 2011 at 1:36 pm
    Yes it was shot on a DSLR. I was not aware of that. I’ll check out the other threads.
    Thanks a lot.
    Himanshu Bhatnagar
