Activity Forums Apple Final Cut Pro Legacy Subtitle suddenly needs render issue
  • Subtitle suddenly needs render issue
    Posted by Frederic Bohbot on December 13, 2007 at 3:48 am
    I have a technical problem. For some reason all titles need to be
    rendered after a certain point on the timeline (they are “red” and
    won’t play), and this happened all of a sudden at the end of the day
    today after hours of subtitling with no problem. I thought the sequence became corrupt, but nothing happens when I copy/paste the whole movie into a new sequence.
    Using FCP 6 – P2 footage in 720p
    Any ideas as to what i’m dealing with??
    Peter Ottosson replied 18 years, 4 months ago 7 Members · 10 Replies
  • 10 Replies
  • Kevin Hamm
    December 13, 2007 at 5:03 am
    I don’t know what you are using for your subtitles, I’m guessing it’s just a text bit, tho, right? What’s probably happened is that you’ve laid the titles over clips that have filters or something else in them. I don’t know without actually looking at your timeline, but that’s where I’d start. The only other thing that you might have done is turned off RT effects via the keyboard or a mis-clicked mouse, so you might check your settings for that.
  • Przemek Pyrek
    December 13, 2007 at 5:04 am
    hello,
    i had the same problem once with a DV project, couldn’t help it :-(.
  • Greg Nosaty
    December 13, 2007 at 5:11 am
    [Frederic Bohbot] “For some reason all titles need to be
    rendered after a certain point on the timeline”
    I had the same problem this week. You have maxed out your real time buffer. It seems to be proportionate to the ram and processor speed, i.e. the more you got, the more you get! You could try to play with your “RT” setting but your best bet is to render some of your sub-titles.
    Just for fun render some of the “green” subtitles and watch what happens to the “red” ones. I bet some of the red batch will turn to realtime.
    cheers,
    Greg Nosaty
    Cinemontage Productions Inc
  • Frederic Bohbot
    December 13, 2007 at 5:36 am
    I’m just using the title tool, it’s just a rough cut that i have to present so i thought this would be super simple and i have about 15 minutes worth of foreign language footage.
    I’ll look into your suggestions in the morning, thank you
  • Jason Porthouse
    December 13, 2007 at 1:36 pm
    Frederick,
    This is not uncommon – I’m working on a heavily subtitled doc and am running up against this phenomenon. I think I remember reading that there’s a buffer for the max number of titles and when you hit it, you need to render. I haven’t found a way around it yet.
    BTW, I can wholeheartedly recommend DH_Subtitle filter from Digital Heaven, though it may be a bit late now you’ve done a lot in title tool.
    HTH,
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Greg Nosaty
    December 13, 2007 at 3:38 pm
    [Jason P] “BTW, I can wholeheartedly recommend DH_Subtitle filter from Digital Heaven, though it may be a bit late now you’ve done a lot in title tool. “
    I second that. Digital Heaven Subtitle tool is easy too use and easy to read.
    cheers,
    Greg Nosaty
  • Martin Baker
    December 13, 2007 at 11:13 pm
    System Settings > Memory & Cache > Still Cache is where the setting is. It’s 10% by default but if you increase it, you’ll get further down the sequence before you need to render.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
  • Jason Porthouse
    December 14, 2007 at 10:51 am
    Excellent!
    Thanks Martin, that’s a great help!!
    Jason
  • Frederic Bohbot
    December 14, 2007 at 1:32 pm
    Thank you Martin!!
    That’s the answer, i figured out the problem form the previous posts, but you gave me the solution. Thank you all.
  • Peter Ottosson
    April 15, 2008 at 5:07 pm
    There is also POPRODSOFT Subtitler that I made to be very simple to work with. Check it out if you’re interested. http://www.poprodsoft.com
