Activity Forums DVD Authoring Subtitle Streams refuses to work
  • Subtitle Streams refuses to work
    Posted by Emma Kjellstrand on October 15, 2008 at 8:06 pm
    I’m having a issue with my subtitles.
    I have a DVD with 4 different languages and 4 different language streams
    My Setup looks like this
    Menu1: Choose language (etc. swedish)
    Menu2: Swedish main menu with buttons for chapter menus.
    Menu3: Chapter menu with buttons for each chapter. Each button is set to subtitle stream 1 (sv) and the view-box is checked
    This setup is the same for all my sifferent languages, except ofcourse that the subtitle stream is set to 2, 3 or 4, depending on which language-menu I’m in.
    Everything works fine in my DSP simulator, but when I play the DVD in a regular DVD-player I always end up with swedish subtitles no matter what language I chose.
    Does anyone know why and have a solution for the problem? I’m pulling my hair at the moment!
    I would really appreciate if anyone would like to answer! 🙂
    e.
    e.
    David Smith replied 17 years, 10 months ago 2 Members · 1 Reply
  • David Smith
    October 16, 2008 at 11:47 pm
    I think I have had this problem. You are probably using the button settings to tell it which stream to play when you leave that button. What you could do is add an end-jump command to that track that sets the subtitle stream to one of the ones that are not being used. Like stream 5. So when it finishes it will turn it on to a stream that does not exist. Then you will start clean again. That’s a cheater way of doing it without resorting to scripting. Make sense?
