Activity › Forums › Apple Final Cut Pro Legacy › Subtitle nightmare on FCP
  • Subtitle nightmare on FCP
    Posted by Frederic Tcheng on January 20, 2010 at 7:29 pm
    Hi all,
    I am having a real mind-puzzle on this documentary project.
    Originally we used DH-subtitles v1. We were very happy with them until we found out that we need to change the size, color and contour of ALL subtitles, and also add a box in order to meet the requirements of a broadcaster.
    Unfortunately it is not possible to modify DH_subtitles en masse, and I really don’t want to have to modify the 1000+ subtitles manually.
    If anyone has a solution, I’d be very very grateful. I vaguely understood that it might be possible to transfer the subtitles to a text file with Title Exchange Pro, then feed them back into FCP using new settings. Does anyone have any insights? Many thanks in advance.
    Frederic
    Frederic Tcheng replied 16 years, 8 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    January 21, 2010 at 12:34 am
    Title Exchange Pro or Traffic might do what you want.
    Or you could try to hack it yourself using xml export & import. You would open up the xml in TextEdit and use find/replace to change the attributes that you want. Do a search here for “xml” and you’ll probably find more detail.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Andreas Kiel
    January 21, 2010 at 2:42 pm
    I already answered Frederic on mail he directly sent to me.
    So just for the records.
    TitleExchange allows to do this.
    Create a generator in a FCP sequence with the new settings and export as XML. In TEP import that XML as template.
    Then convert the subtitle XML using an XML to XML conversion.
    Spherico
    https://www.spherico.com/filmtools
  • Frederic Tcheng
    January 21, 2010 at 5:10 pm
    Thank you for the tips Arnie and Andreas!
    I will try it and if I run into trouble for some reason I’ll post again here.
    Best,
    Frederic
