Activity › Forums › DVD Authoring › Subtitle menu in DVD studio pro 4
Posted by Zeljko Tomic on November 30, 2010 at 3:02 pmHi!
I have 7 clips and each clip has 2 subtitle tracks, English and Italian. I wanted to create DVD where the viewer first chooses language from the first menu and then goes to the second menu with 7 clips. Is that possible id DVD studio pro 4? Or do you know some better solution for this?Daniel Ludwig replied 15 years, 9 months ago 3 Members · 5 Replies -
Daniel Ludwig
December 1, 2010 at 3:36 amHi Zeljko,
I would do this with scripting, that wouldn´t be that complicated. Your first menu-buttons (language-select) would jump to a script where you automatically set an language ID.1st button would be english, 2nd italian. so you would get the button-ID out of SPRM8 and set it as a language ID to GPRM1.
1. move SPRM8 to GPRM1
2. div GPRM1 by 1024
3. jump to the next menu button no.1you´ll need to divide GPRM1 by 1024 because otherwise you´ll get values like 1024 or 2048.
within the next menu you should link from every button to another script.
1. if GPRM1 = 1 then set subtitle/audio (english)
2. if GPRM1 = 2 then set subtitle/audio (italian)
3. jump film 1, 2, ….if you´ll read out SPRM8 within this menu you can do a if GPRM2=1, 2, 3… then jump film 1, 2, … as well, but you need to keep the language ID, so you need to read out SPRM8 (again) to another GPRM, for example GPRM 2.
note: this is not the 100% correct syntax of DVD SP-scriping, but it´ll show you the way as it could be done.
cheers
danny
Zeljko Tomic
December 1, 2010 at 12:26 pmCan you please give me more details about this, I’m totally new to scripting in this program.
Daniel Ludwig
December 1, 2010 at 4:53 pmHi again,
you should learn the basics first!here´s a good website that can show it to you:
https://www.dvdstudiopro.ch/english/index.htmlthere is also a lot information within DVDSP user manual.
I guess that will help.
cheers
danny
Michael Sacci
December 1, 2010 at 5:13 pmThat site has been linked to before, everything on it is for DVDSP 1.5 which was a totally different program than what we have now. There was a total rewrite of DVDSP.
Daniel Ludwig
December 1, 2010 at 7:48 pmoh damned – you´re right,
I thought it was for DVD SP 2 and newer as well. sorry.so we need to go a different way.
here is the 1st script, that you need to link to from the language-select-menu, first button should be english, 2nd button should be italian, both buttons jump to this script.
with this script you set a specific value for for each language
value 1 for english, value 2 for italian.
language-ID-script:
1 mov GPRM0, SPRM 8
2 div GPRM0, 1024
3 jumbo main menu: button 1next one will be the track selction-script, which will set the subtitle and jump to your specific title. all your main menu-button should link to that script
track-select-script
1 mov GRPM1, SPRM 8
2 div GPRM1, 1024
3 set system stream St(1 (On) if GPRM 0=1)
4 set system stream St(2 (On) if GPRM 0=2)
5 jump track 1::chapter1 if (GPRM 1=1)
6 jump track 2::chapter1 if (GPRM 1=2)
7 jump track 3::chapter1 if (GPRM 1=3)
x jump track x ::chapter1 if (GPRM 1=x)you see that you need to jump to your specific tracks. button 1-track 1, button 2-track 2 and so on…
I hope this would help.
cheers
danny
