Activity Forums Maxon Cinema 4D Subsurface Scattering
  • Subsurface Scattering
    Posted by Brad Goosen on September 25, 2006 at 2:55 am
    Hi Cowsters
    I’m using 4d v9.6 and i’m trying to add subsurface scattering but i can’t find it anywhere. i’ve looked for it under effects but its nowhere to be seen. is it called something else in 9.6 or is it found somewhere else?
    thanks in advance
    brad
    Brad Goosen replied 19 years, 11 months ago 3 Members · 3 Replies
  • Mylenium
    September 25, 2006 at 7:35 am
    Use the ChanLum shader. It’s a simplified SSS shader. You can get another one with the Advanced Render module that is more sophisticated. There’s also Lumen from 3D Attack and I’m sure in finalRender you can also find this functionality.
    Mylenium
    [Pour Myl
  • Arndt Von koenigsmarck
    September 25, 2006 at 6:13 pm
    SubSurface Scattering needs the Advanced Renderer.
    If you don’t own that module there are some other plugin shader available that do pretty much the same.
    Beside the ones already mentioned there is also Translucent Pro and Vreel Skin:
    https://www.vreel-3d.de/html/plugins.html
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vonkoenigsmarck.de
  • Brad Goosen
    September 26, 2006 at 5:57 am
    thanks for your help!!
