Activity Forums Adobe After Effects Substituting a 3D solid layer from a AFX comp with a video in Premiere
  • Substituting a 3D solid layer from a AFX comp with a video in Premiere
    Posted by Emil Stefanow on August 23, 2018 at 1:05 pm
    Hi folks!
    My first question is quite tricky and I have tried everything possible but no success so far.
    Here’s the issue.
    I have a 3D comp in After Effects CC2018 with a camera and a 3D solid layer that’s flying around (1920×1080, as a place holder).
    I have imported the 3D comp in Adobe Premiere Pro CC2018 and would like to substitute the 3D solid layer with a video footage from Premiere Pro (I guess from a specified video track).
    For now several ideas came to my mind as a solution (exporting the 3D Comp as a 2D corner pin data but how do I get it into Premiere)… So far no real solution. The question is: how do I get the link between AFX and Premiere with this one?
    Any ideas? I would be super thankful for awesome suggestions!
    Best regards
    Emil
    Emil Stefanow replied 8 years ago 2 Members · 8 Replies
  • 8 Replies
  • Kalleheikki Kannisto
    August 24, 2018 at 1:22 pm
    Replace the 3D solid in After Effects with your footage of choice.
    Senior Graphic Designer
  • Emil Stefanow
    August 24, 2018 at 1:26 pm
    Hi Kalleheikki,
    Thank you for the answer! ☺
    How do I replace a AFX Solid with a footage in Premiere (not FROM Premiere but IN Premiere)?
    Thank you!
    Best regards
    Emil
    August 24, 2018 at 1:35 pm
    Why do you want to do it in Premiere?
  • Emil Stefanow
    August 24, 2018 at 1:40 pm
    The customer doesn’t have After Effects and I would like to deliver a kind of a template where he can just substitute the footage. Also possible with Essential Graphics?
    Thank you!!!
    August 24, 2018 at 1:43 pm
    Ok, this would then be a question for the Premiere forum.
    August 24, 2018 at 3:28 pm
    I kinda suspect you will have to manually animate using Premiere corner pin to try and match the AE render.
  • Emil Stefanow
    August 24, 2018 at 3:33 pm
    Thank you Kalleheikki,
    That’s my suspicion, too. Unfortunatelly.
    I don’t think it’s possible to “transfer” the corner pin data from AFX into AE directly, or? That would be a big help.
    Best regards
    Emil
  • Emil Stefanow
    August 29, 2018 at 10:24 am
    Thank you Dave.
    Unfortunatelly the customer doesn’t have any AFX knowledge (and the AFX setup isn’t that easy for a newbie.
    So I guess we stick to the AFX solution and deliver a final video. :/
    Best regards
    Emil
