Activity Forums Cinematography Substitute tv for a professional monitor
  • Boyd Mccollum
    June 30, 2006 at 4:34 am
    You can substitute an ordinary TV, but it needs to be calibrated correctly. Do a google search on the web and you’ll find many sites that talk about doing this. Here’s a couple I got from the search “calibrating+ntsc+monitor+TV+blue” (just from the first couple of links, no endorsement intended). You will need a blue filter to place over your TV to do all the calibrating required:
    https://www.videouniversity.com/tvbars2.htm
    https://myweb.accessus.net/~090/how2adj.html
  • Tim Kolb
    July 3, 2006 at 3:24 pm
    It should be noted that a precisely calibrated video monitor is necessary to prepare material for broadcast. For your own use or non-broadcast playback, it’s easier to cheat a little…
    I would try to find the best quality telkevision you can afford…and it has to have a video input of course, not just an antenna input (which almost all modern sets have…)
    I would visit the two links specified above and get some background on calibrating television monitors…but I would also check out some links on reading waveform monitors and vectorscopes.
    https://www.larryjordan.biz/articles/lj_scopes.html (FCP is featured, but the info is solid.)
    There must be more, I’m sure… I can’t find any specifically on scopes in PPro.
    If you understand what the scopes are telling you, the absolute accuracy of your monitor will become less of an issue.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
