Activity Forums Adobe After Effects Expressions Substitute keyframe values with values from point controls or sliders (but …
  • Substitute keyframe values with values from point controls or sliders (but …
    Posted by Christopher Hesse on May 8, 2024 at 9:52 am
    keep the keyframe curves)
    I have an expression that lets me substitute the value of one keyframe with values from a point control or slider. This is the expression, which I originally found here (all the way at the end of the page, thanks Dan Ebbert!):
    https://community.adobe.com/t5/after-effects-discussions/dynamic-keyframe-value-using-expression/td-p/10130410
    var newValue=thisComp.layer(“Tief-Blau Farbfläche 1”).effect(“newValue”)(“ADBE Point Control-0001”);
    var firstValue = key(1).value;
    var lastValue = key(2).value;
    if (firstValue[0] < lastValue[0])
    x = linear(value[0],firstValue[0],lastValue[0],firstValue[0],newValue[0])
    else
    x = linear(value[0],lastValue[0],firstValue[0],newValue[0],firstValue[0]);
    if (firstValue[1] < lastValue[1])
    y = linear(value[1],firstValue[1],lastValue[1],firstValue[1],newValue[1])
    else
    y = linear(value[1],lastValue[1],firstValue[1],newValue[1],firstValue[1]);
    [x,y]
    What I’m looking for is an expression that lets me do the same for a variable number of n keyframes. I guess it could be done with a “for -> each-loop”, but my own humble expression-whiz doesn’t cut it and so I’m stuck. Does anybody have an idea?
    Christopher Hesse replied 2 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
