Activity Forums Apple Final Cut Pro Legacy Subpixel rendering
  • Subpixel rendering
    Posted by Oscar Mora on January 17, 2006 at 4:48 pm
    I am new to FCP. I have this project with lots of graphics and texts that some where generated withing FCP and some come from Photoshop and so… When I make scale and/or make position adjustments of this graphics I get this jagged borders. Is this due to the lack of subpixel accuracy in the render?
    Thanx!
    Annaël Beauchemin replied 20 years, 8 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    January 17, 2006 at 6:02 pm
    First you should be judging the quality of the images on an external video monitor, and not rely on the Canvas to show you the actual quality of the renders. They might look fine there. (or not)
    If you create titles in Title 3D and use it’s positioning in it’s controls, you’ll find much better looking titles. (especially with DV material).
    Any time you use the motion tab to move a title, you are turning it into a bit mapped graphic, and it won’t look as good as a vector based graphic will look (which is what Title 3D creates).
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Matthew Brunn
    January 17, 2006 at 6:03 pm
    It could be due to that. Since we know nothing about the graphics your using or the resolution your editing in it’s pretty hard to tell anything about your project or give any advice.
    Hope this helps-
    Matthew
    Dual 500 G4
    OSX 10.3.9
    Ram 1.38
    FCP 4.5/AE 6.5/DVDSP3
  • Annaël Beauchemin
    January 19, 2006 at 5:21 am
    are you using FCP v5 ?
    before v5, there was no filtering on scaling/translate of layers. This made high resolution graphics appear blocky and flickery when animated. so if you’re using FCP 4.5, I you should either do your text/graphics in AE or then updgrade to FCP 5.
    Furthermore, i’m not sure that the default text generator does subpixel rendering…
