Activity › Forums › Adobe After Effects › submerging a camera underwater
  • submerging a camera underwater
    Posted by Nicholas Heathcote on October 15, 2010 at 4:59 pm
    was wondering whether anyone could help me on something I am attempting for a short animation in after effects…whether or not i can explain what i want to do is another matter.
    I have built two scenes in after effects (a swamp on top and an underwater scene on the bottom. I am following a really good andrew kramer tutorial from video copilot as to how to mover the camera down from one scene to another (like this but the bottom layer being water instead of basement https://www.youtube.com/watch?v=9dv5Akg0IXY). What i am having difficulty with is the water, I want the water’s surface to have a subtle movement and the camera to see the small ripples and waves as the lens passes thru the water (with this sort of look as you go thru https://farm4.static.flickr.com/3381/3231381180_2af1a3173a_z.jpg )
    does that make any sense? can anyone help?
    many thanks,
    Nick
    Richard Van den boogaard replied 15 years, 11 months ago 2 Members · 4 Replies
  • Richard Van den boogaard
    October 15, 2010 at 6:22 pm
    Red Giant’s Psunami is probably a good solution: https://www.redgiantsoftware.com/products/all/psunami/
    It would probably mean that you’ll have to redo the bottom part of your composition with this plugin, but animating water probably is a lot more complex.
    Richard van den Boogaard
    Freelance cameraman • Glidecam Operator • Editor • YouTube expert
    October 15, 2010 at 6:25 pm
    Check the second part of the tutorial – if features exactly what you need: https://cache.redgiantsoftware.com/_assets/uploads/file/community-tutorial/gs_psunami_part2.mov
  • Nicholas Heathcote
    October 19, 2010 at 9:38 am
    That is brilliant! exactly what I need! Thanks! It seems to have sky and sun built in to it do you know if that can be removed?
    Cheers!
    Nick
    October 27, 2010 at 11:06 am
    I believe the plugin allows you to switch off the sky/sun layers and replace those with your own…
    Good news – I just received word last night that RGS is now offering this with a $100 discount ($99 instead of $199). Enter Coupon Code 199FOR99 during checkout to redeem your discount. Offer valid for the next 5 days.
