Activity Forums Maxon Cinema 4D Submarine splash in Cinema 4D
  • Submarine splash in Cinema 4D
    Posted by Tony Marcuccino on February 18, 2011 at 7:28 pm
    Hey guys,
    Having trouble working out creating a splash in Cinema 4d. I posted a few week back that I needed to make a splash of water coming from a submarine that was breaking the surface of the ocean. I received a post that sent me back to a tutorial on Lynda.com on how to create a splash of water with metaballs but no matter how I tweak it it doesn’t seem to look like water shearing off of and emanating from a surfacing submarine. The water seems too thick and the drops look like flying spheres. I have attached a picture that
    accurately depicts what I need.
    Thank you,
    Tony
    Tony Marcuccino replied 15 years, 6 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    February 18, 2011 at 9:07 pm
    I think you’re going to have a real hard time doing that without a dedicated liquid simulator like DPIT Effex or RealFlow.
  • Nick Herber
    February 21, 2011 at 4:52 am
    Sorry transmission error, see other message!
  • Nick Herber
    February 21, 2011 at 5:36 am
    Hy Tony,
    Sorry for my bad English,
    First try with PyroCluster to create a basic Waterfall that you can multiply and combinate together to make numerous varations by changing scale, speed, transparency,etc. to create downfalling Water overall your Submarine by setting the 3 PyroCluster Shape Scales to 2 / 10 / 0,2, Volume 90%, Luminosity 12, Density 5, Emitter Birthrate around 24, Angle Horiz. 15° Vertic. 5°, Visibility 100%, Speed minimum 330. For the splashing Water always use PyroCluster to make some combinations with White/Blue shaded Explosions and inside an other Particle Emitter/Gravity for the different sized Waterdrops. That needs some time of experimentation and a long Render Time, but you can obtain a verry photorealistic result.
    Here a Test Pic with simple Waterfall, without Waterdrops Emitter.
  • Tony Marcuccino
    February 22, 2011 at 3:03 am
    Thank you for your response and I really appreciate you explanation in any language. You are very kind to to take the time to explain.
    I will follow your instructions and see if i can make it work.
    Thank you,
    Tony
