Activity Forums Maxon Cinema 4D Subdivision Surface–light only one object in inside?
  • Subdivision Surface–light only one object in inside?
    Posted by Tim Vining on November 27, 2022 at 5:58 pm
    Is there a way to light only one of multple objects inside a Subdivision Surface? For example, if I place two spheres (A & B) in a null, inside a SS container and tell a single light in the scene to illuminate only sphere A, it doesn’t light sphere A (or B), but it does light only sphere A if I turn off the SS. If I turn the SS back on and tell the light to illuminate the whole SS, it illuminates both spheres. Is there a way to light only sphere A in this scenario?
    Michael blaq replied 3 years, 9 months ago 2 Members · 1 Reply
  • Michael blaq
    December 5, 2022 at 10:14 pm
    Hi Tim, the issue was with your scene setup. You will have to break up your hierarchy by having sphere A and B in a separate Subdivision Surface(SS) object in order to only illuminate one object/mesh at a time. See my screenshot below for illuminate each object separately. Hope this helps. Cheers!!
    Running on Cinema 4D 2023.
