Activity › Forums › Apple Final Cut Pro Legacy › Subclipping Sequences keeping timecode
  • Subclipping Sequences keeping timecode
    Posted by Randolph Harrison on June 16, 2008 at 6:13 am
    Hi All,
    I have a huge sequence which I need to make OMF’s from. Each scene is almost the 2 gig limit for OMF’s. I have tried marking in & out, making a subclip, but it doesn’t keep the timecode where it lies in the sequence. Do I have to manually change the timecode on the subclipped sequence.
    I have also tried marking in & out and exporting the OMF’s, but Final Cut seems to want to do the entire track.
    Is there a simpler method for me to export parts of the sequence which will keep their timecode in relation to the original sequence?
    Thank you in advance for your help and advice.
    Sincerely,
    Randy
    Final Cut Pro 5.1.2
    PowerMac G5 Quad, 2.5, 8 gigs ram
    Burley enclosures with 10 x 500 gig Seagates.
    Tempo II card
    2 x 23″ cinema displays.
    Captain Mench replied 18 years, 3 months ago 2 Members · 1 Reply
  • Captain Mench
    June 22, 2008 at 5:16 pm
    Ugh… this does sound like a problem for you.
    Hmmm
    Can you chop the sequence up with straight cuts and put them into new sequences?
    CaptM
