Activity Forums Apple Final Cut Pro Legacy Subclipping select tracks
  • Subclipping select tracks
    Posted by Martin Nelson on June 7, 2010 at 3:52 pm
    How do I make a subclip that doesn’t include all the original tracks of a clip? I am pulling soundbites from interviews, which I will then export for use on a website and I would like my subclips to include video and audio channel 1, but not audio channel 2.
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 9, 2010 at 6:22 pm
    I don’t think there’s a way to create a subclip that doesn’t contain all the tracks of the master clip that it came from.
    You could export them as selfcontained movie however after you delete the tracks from a sequence etc…
    It’s likely easier to make the subclips, then just not edit the audio track into a sequence you want to lose using the track buttons in the timeline window.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
