Activity › Forums › Avid Media Composer › Subclipping from Subclips
  • Subclipping from Subclips
    Posted by Robbie Gibbon on November 1, 2011 at 9:41 pm
    I am currently in the process of syncing audio to rushes shot on the Alexa. The number of audio channels varies from 4-8 depending on the setup. I am currently syncing the footage to the audio in a sequence. I then in/out each synced clip & option drag to make a sub-sequence. I then autosync this to create a subclip, the master clip & synced audio.
    The editor would like to only work with the mono mix which is on track 1 and be able to match frame back to the clip will all tracks when require. I have subclipped my subclips turning off all tracks of audio except the required track so we now have a clip with 1 video layer & 1 audio layer.
    My problem is that when you match frame this ‘mono-mix’ subclip, it goes straight back to the mute master clip, skipping the synced subclip.
    Does anyone know how this can be achieved so the editor can happily work with the mono-mix clip knowing he’ll be able to get back to the seperate mics when required?
    Any help would be greatly appreciated.
    Robbie Gibbon replied 14 years, 10 months ago 2 Members · 2 Replies
  • Job Ter burg
    November 1, 2011 at 9:57 pm
    Matchframe from the sequence to the synced clip. Then, on the SOURCE side, DEselect the V track and hit MatchFrame again.
  • Robbie Gibbon
    November 8, 2011 at 7:55 pm
    That is exactly what we have ended up doing. I have been assisting on a project where the editor was yet to start so I was frankly ‘over-worrying’ the details of the project.
    Thanks very much for your help & speedy reply.
