Activity Forums Adobe Premiere Pro Subclip Problems
  • Subclip Problems
    Posted by Aaron Hartley on July 1, 2009 at 3:19 am
    I’m having issues making subclips from the timeline in Premiere Pro CS4. I am attempting to sync separately recorded audio and video. I can make a subclip from just the video but when I link the audio it won’t let me. I can nest the files but I need to export an OMF so it can be edited in Pro Tools. I assume that all the audio tracks in the nested file are not exported just the single one in the timeline. Any help would be much appreciated!
    Alex Udell replied 17 years, 2 months ago 2 Members · 3 Replies
  • Alex Udell
    July 1, 2009 at 1:48 pm
    Hiya…
    Your post is a little unclear…
    so you are:
    1) Making a sequence
    2) Putting separate Audio and video on to the timeline
    3) Loading Sequence into the source viewer
    4) Marking IN and Out
    5) Dragging from Source Viewer to Project panel
    What happens next?
    You get the video only?
    Or you get a clip, but Premiere won’t export it properly for use in Pro Tools?
    Alex
  • Aaron Hartley
    July 1, 2009 at 3:24 pm
    Thanks so much for responding. I’ve done what you suggested but when you drag it over nothing happens.
    When you edit the clip in the timeline and ctrl drag the clip to the project panel it won’t allow you to drop it there. If you unlink and just select the video track it allows you to make a subclip with just video.
    You can make subclips from the source file in the source monitor with audio but that doesn’t help when I need to sync audio from another source.
    I can nest files but my fear is that the OMF exported will have only one track of audio for a clip that has at least three.
    I’m working with MXF files. Would that have any impact on what I am trying to do? Thanks for your help.
    Aaron
  • Alex Udell
    July 1, 2009 at 8:32 pm
    I thin you are missing one step….
    Drag the sequence icon from the Project Panel to the source viewer
    and then try to make sub clips from the source viewer to the Project panel..
    If that does not work…then well…I suppose you’d likely have to export your Timelines as new clips….
    then you could make sub clips from the new media
    Alex
