Activity Forums Apple Final Cut Pro Legacy Subclip buffers
  • Subclip buffers
    Posted by Darryl Thomson on December 1, 2006 at 12:13 pm
    When I drag a tightly edited subclip into the sequence. If I wish to do a dissolve or similar effect, I a warned I have not enough material. Is there a way to set buffer material on either side of the in and out points so spare material is available?
    Dazzer
    Nick Meyers replied 19 years, 9 months ago 2 Members · 1 Reply
  • Nick Meyers
    December 1, 2006 at 11:47 pm
    only manually, at the time you create the subclip.
    you can UN-subcliop the subclip, though.
    select it in the timeline,
    Modify Menu > remove subclip limits
    nick
