Activity › Forums › Apple Final Cut Pro Legacy › Sub-Frame (Video)
Sub-Frame (Video)
Posted by John Livings on February 17, 2010 at 10:08 pmCan I Make a “Sub-Frame” to the Video in FCP ?
I use Captain Mench’s Tutorial for Audio sub-frames.
I know I have asked this question before, And was wondering if anyone has found a way to do it?
John
Tom Wolsky replied 16 years, 4 months ago 5 Members · 8 Replies -
Tom Wolsky
February 17, 2010 at 10:49 pmWhat would a subframe look like? A cropped frame?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Shane Ross
February 17, 2010 at 11:39 pmThere is no such thing as SUB FRAME video…or film. A frame is the full picture you see on the screen. Anything less, as Tom pointed out, would be like half a picture. Video doesn’t work that way.
Shane
Read my blog, Little Frog in High Def -
John Livings
February 17, 2010 at 11:49 pmHi Tom,
A sub-frame would be a part of one frame, e.g., 1 Frame =1/30 of a second (29.97) A Sub Frame would be the ability to cut the frame into say 1/100s.
Using Multi Cameras (in my case 3 or 4) Non Time Code Synced, It would be nice to move the Video clip left or right Less than One Full Frame (Just like Capt. Mench’s Audio sub frame adjustments)
This would allow me to line up any number Video Clips to a more accurate position for editing.
I am able to sync up my Multi Track Recorder to any One of the Cameras Video/Audio Clips, However I can’t move the rest of the Video clips to match the first video clip.
Thanks for any suggestions,
John
Shane Ross
February 17, 2010 at 11:58 pmAgain, there is no such thing as sub frame VIDEO. Audio, yes. So the Capt’s tutorial is right for that. But in video, there is nothing shorter than the frame you are looking at.
Shane
John Livings
February 18, 2010 at 12:04 amHi Shane and Tom,
I thought that was the case, Just hoping it could be done.
Thanks for your input,
John
Michael Gissing
February 18, 2010 at 1:00 amIn practical terms, the smallest unit in video is the frame. In audio it is the sample. There are approximately 2000 samples per frame of video (@ 25 fps) so many systems allow audio to be moved in sub frames compared to picture which can only really be moved in whole frames.
Chris Edwards
May 27, 2010 at 11:38 pmIt is not quite true to say that anything less than a frame cannot be edited in video. Whilst editing systems will only allow a minimum edit duration of one frame, it is possible to effectively perform half-frame edits ie one field edits in an interlaced environment. By changing the chosen edit field in the menu settings on the record VTR (eg a DigiBetacam) from field one to field two the machine will perform an edit half way through a field. Now switch the machine back to field one, edit on the next frame and you have effectively performed a one field drop in or edit. Much simpler to do with an edit controller than FCP’s edit to tape function (which I personally find less than friendly).
Tom Wolsky
May 28, 2010 at 1:38 amThis isn’t relevant to editing in a digital environment, only when editing to a tape based environment.
All the best,
Tom
