Activity Forums Apple Final Cut Pro Legacy Sub-Frame audio slipping not working…
  • Sub-Frame audio slipping not working…
    Posted by Matthew Cohn on December 16, 2010 at 4:29 pm
    Hello,
    I’m trying to sync up audio using the sub-frame audio slipping, but I’m not sure what I’m missing. I open the audio clip from the sequence into the Viewer, hold down Shift and drag the palyhead in the audio tab in the Viewer to the desired position, release the Shift key, release the mouse and type “I” to slip the audio clip to that position. However, when I do this all that happens is I wind up setting a new In for the audio clip in the Sequence. Am I missing something?
    Thanks for your help,
    Matt
    Matthew Cohn replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
