Activity › Forums › Creative Community Conversations › Sub-frame Audio editing – FCP X vs Premiere
Morgan Reese replied 10 years, 9 months ago 13 Members · 41 Replies
Morgan Reese
November 30, 2015 at 5:14 pmI’m having the same issue as Oliver Peters in that I can blade on any subframe but the next one has to be a frame away. I believe in Pr you can select 1 subframe so you can’t in X? I was able to make a 1 subframe range and keyframe it to zero in between but I would like to blade wherever I want in and out and slip to remove unwanted audio. Am I missing something?
tia
