Activity Forums VEGAS Pro sub clips
  • sub clips
    Posted by Roger Bansemer on August 11, 2010 at 10:02 pm
    I need to reduce the size of some clips so I put them in the trimmer and make a sub clip. The clip then shows up in the “project media”. Fine so far. Now I click on “Explore containing folder” and it’s not there. It doesn’t show up in either Vegas explorer or Windows explorer.
    I have a clip named gator.m2t. The subclip names it gator.m2t-subclip1
    Where the heck is it?
    Roger Bansemer replied 16 years ago 3 Members · 4 Replies
  • Mike Kujbida
    August 11, 2010 at 10:06 pm
    A subclip is only a pointer (i.e. a virtual clip) that links to the trimmed clip.
    Therefore the only place it will show up is in the Vegas project where it originated.
    You’ll have to render it to the desired format if you want a “hard copy” of it.
  • Roger Bansemer
    August 11, 2010 at 10:34 pm
    I was afraid of that! Thanks
    Sure with there were an easier way to render clips which I would like shortened to save space.
  • Jeff Schroeder
    August 12, 2010 at 2:23 am
    Roger,,You can use save-as and check copy-media and it will trip your original files to save with the .veg
    I use this all the time for archiving.
    I would clear out any unused event from the project media before saving.
    Jeff
    http://www.narrowroadmedia.com
  • Roger Bansemer
    August 12, 2010 at 3:34 am
    Hi Jeff,
    The only files it will trim to size are the old .avi files. It doesn’t do a thing to m2t or m2ts files. They remain has huge as ever even if the clip is only a second long.
