Activity Forums Adobe After Effects Stuttery Computer Image Capture
  • Stuttery Computer Image Capture
    Posted by Phillr on April 30, 2006 at 10:39 pm
    I used a special program to capture my movements/actions on my computer monitor. It created an AVI movie file that I exported to Uncompressed Quicktime. I brought it into After Effects, didn’t change the scaling, placed it into a DV NTSC composition, and did some masking effects to it.
    Then I exported it a few times: Field Render Off/Upper/Lower. Then I brought the file into my Meridien-based Avid Xpress 4.6. Again, here I used 3 different field import settings: Off/Upper/Lower, so I ended up with 9 files in my bin (all possible combinations of field rendering from AFX -> Avid).
    I viewed all 9, every single one is ‘shimmering’. Sort of like a slight shaking, similar as if there was some field order issue. Anybody know what’s going on? How do I fix this?
    The program my friend used to capture the video doesn’t let us adjust any of the capture parameters.
    Phillr replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
