Activity Forums Panasonic Cameras Stuttery 1080 vs 720
  • Stuttery 1080 vs 720
    Posted by Steve Roberts on February 21, 2010 at 9:43 pm
    I am shooting with a HPX500. I have trouble with stuttering footage when shooting in 1080i 24p mode. I know that large DOF, pan speeds and shutter settings play a factor. But when shooting the same subjects in 720 24pn mode with no shutter, I don’t have the same issues. Can anyone help shed some light on this issue? Does anyone have any good setting adjustments to help?
    Also, if I strip the pull-down from 1080i 24pA footage using Final Cut Pro, does it make that footage effectively 1080p?
    -S.
    Michael Sacci replied 16 years, 7 months ago 2 Members · 1 Reply
  • Michael Sacci
    February 22, 2010 at 1:54 am
    [Steve Roberts 2] “Also, if I strip the pull-down from 1080i 24pA footage using Final Cut Pro, does it make that footage effectively 1080p? “
    Yes, in FCP it will be 1080p @ 23.98 sf, the frame is broken up into two segments but these segments are put together to make a perfect frame. No temporal difference between the segments.
    Are you seeing the shutter after you remove the pulldown? Can you post a sample clip?
