Activity Forums Apple Final Cut Pro Legacy Stuttering SloMo
  • Stuttering SloMo
    Posted by Jim Murphy on May 15, 2012 at 2:22 pm
    Working on an SD project. Footage was captured in it’s native format (DV/DVCPRO NTSC). When I insert a clip into the sequence and slow it down to say 35 percent, the clip looks like it’s stuttering after its rendered. It looks fine BEFORE render however.
    How can I get tis stuttering to stop?
    Jerry Hofmann replied 14 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 15, 2012 at 4:03 pm
    Set the speed in FCP, then send the file to Motion. Open the timeing pane, and select “optical flow” for the render… render and save.
    It should look better with anything where there is no panning involved.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
