Activity › Forums › Panasonic Cameras › “Stuttering” problem with HMC150 footage
Posted by Daniel Schultz on October 16, 2009 at 1:51 amI’m using HMC150 footage on FCP 6.0.6 on a new macbook pro, 8 gigs ram.
I notice a problem when panning or an object is moving across the screen…the movment is not smooth, it skips and jumps, seemingly randomly. FCP is set to pro res 422, and I set QT to High Performance in preferences. It still does that. It concerns me because the problem is not there when using similar footage (1080/30p) from a Sony XD CAM. That footage looks smooth, both in FCP and quicktime.Am I doing something wrong? I really hope it’s not a flaw of this camera? Too late to return it, and I love it otherwise!
Dan S.
Corby Anderson replied 16 years, 5 months ago 6 Members · 14 Replies -
Tash Glenn
October 16, 2009 at 2:28 amIm having the same issues…Does anyone know what the best time line setting for 1080/60i SD cards Panasonic HMC-150 is?
Noah Kadner
October 16, 2009 at 2:58 amAs in frame skipping- meaning your hard drive is not fast enough to play back Pro Res. Or as in strobing- meaning you shot fast moving motion too fast or without sufficient shutter.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
Call Box Training
DSLR Cinematography Blog -
Tash Glenn
October 16, 2009 at 5:13 amI believe i zoomed out too fast because it happens with two shots and the rest of the video looks fine, i slowed the clip down 75% and I tried smoothcam filter too but that didnt look good either…any other suggestions?
Daniel Schultz
October 16, 2009 at 10:27 amIt’s not the stobing issue, because I took care to pan very slowly. It’s the skipping. Would it be a hard drive issue? I ordered the 7200 rpm hard drive for the 17″ macbook Pro. I thought that would be fast enough. I also have an external 7200 ESATA drive, but haven’t been using it, because it’s convenient to edit without hooking up to it.
But why would the problem happen on the HMC150 footage and not on the other HD footage from the Sony?
Appreciate your help!
Dan S.
Noah Kadner
October 16, 2009 at 1:41 pmLive and learn…
Noah
Call Box Training
Noah Kadner
October 16, 2009 at 5:47 pmThat’s not fast enough for ProRes- especially HQ mode. Try the ESATA.
Noah
Call Box Training
Daniel Schultz
October 17, 2009 at 6:12 pmI will, once I get back to my ESATA External. So, is this a problem only in playback? In other words, do I need to transcode the footage again?
Dan S.
Noah Kadner
October 18, 2009 at 4:46 pmProbably will be fine- you’ll know by looking at it.
Noah
Call Box Training
Daniel Schultz
November 3, 2009 at 11:20 amHi Noah,
I tried playing back using the ESATA external drive, and I’m still having the same problem. The scene is of a school bus, rather close up, moving from one side of the screen to the other. If you care to take a look, the video’s playing on our website at https://www.scholastic.com/administrator. It’s one of the early scenes in the video within the first minute.
Interestingly, I had a videographer shoot a similar scene of other school busses. He shot on SD, not sure what the camera was, but it was a pro SD model of some sort. I believe their both 30p. His footage of the schoolbus moving through the frame is smooth–no stuttering.
What do you think? If you had a chance to look at the link/footage I sent, do you think it’s just a matter of being too close to a large moving object, thereby giving the effect of panning too quickly? And if that’s the case, why would an SD camera (inferior in quality to the HMC150 I assume) not have that problem?
Thanks again for your time
Dan S.
Corby Anderson
April 13, 2010 at 8:48 pmGents – Just chiming in that I’ve encountered the same problem with my HMC 150. I see it regularly in footage, like a single frame is skipped and usually on moves. I pan and zoom slowly in the instances that I see it happen.
It’s getting to be quite annoying.
Corby Anderson
