Activity Forums Adobe Premiere Pro stuttering playback cc2014
  • stuttering playback cc2014
    Posted by Tom Adams on March 12, 2015 at 1:17 pm
    still trying to figure out why I can’t get smooth playback with cc 2014.
    here are the file properties..
    File Path: /Volumes/09 Reelife GDrive 1TB/bike ways mtg 3/10/15/PRIVATE/AVCHD/BDMV/STREAM/00001.MTS
    Type: MPEG Movie
    File Size: 4.0 GB
    Image Size: 1920 x 1080
    Frame Rate: 29.97
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 01;20;05;09
    Pixel Aspect Ratio: 1.0
    wondering what my sequence settings should be? My sequence settings were set to ARRI Cinema for some reason…
    any other specific things to check? I’ve looked at a lot of the preferences and switched a lot of things but am seeing no improvements…
    Regards,
    Tom Adams – Director/Owner
    Reelife Documentary Productions
    “cool digital video stuff…not boring or dumb”
    http://www.reelifeproductions.com
    Williamsburg, MA, USA
    http://www.FolktographybyTom.com
    https://Folktography.zenfolio.com
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
    Panasonic AGAC90, Canon D60 DSLR
    David Baud replied 11 years, 5 months ago 2 Members · 1 Reply
  • David Baud
    March 12, 2015 at 2:52 pm
    Have you tried creating a sequence from this clip by dragging it to the template icon? still the same behavior? I would suspect the codec being an issue for your “old” cpu? have you tried to convert to ProRes? does it still stutter?
    David Baud
    Post & VFX
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
