Activity Forums Apple Final Cut Pro Legacy Stuttering Motion on pan shots
  • Stuttering Motion on pan shots
    Posted by Areful Eeslam on September 5, 2011 at 11:57 pm
    Hello everybody, I want to share a problem (showing some clips i shot) may be someone enlighten me. I am having disgusting stuttering motion effect only on pan shots. I want some opinion may be solution; is it rolling shutter (the shots aren’t too fast), codec problem (im editing on native codec sequence on FCP7), or something more technical. Please take a look….
    The first clip i shot with Sony EX3 (with body lens) at 25fps, 1080P.
    https://reels.creativecow.net/film/stutturing-problem
    Im editing XDCAm EX 1080 25p sequence, which is native
    This shot i used Panasonic HVX200 (body lens) at 25fps, 720PN
    https://reels.creativecow.net/film/stuttering-problem-2
    Again ive edited native DVCPRO 720 25P sequence.
    Now please helkp me out somebody pointing whats wrong….
    Areful Eeslam replied 15 years ago 2 Members · 3 Replies
  • Chris Tompkins
    September 6, 2011 at 3:55 pm
    That is what 25p looks like (or 24p)
    Shoot 60i or 60p to avoid.
    Chris Tompkins
    Video Atlanta LLC
  • Areful Eeslam
    September 8, 2011 at 12:42 pm
    Chris Tompkins
    Video Atlanta LLC
    If i conform the project to 60p (output), can i get rid of the strobe motion problem.
    Thanks for comment though.
  • Areful Eeslam
    September 8, 2011 at 1:40 pm
    Should i convert xdcam into prores422 60p open into a new sequence & import the xml, will that solve the problem?
    Another problem, sometimes while i render some of the speed ramp footage using twixtor other twixtor applied footage requires render, even some times footage applied with MB looks requires render which is a ghostly problem i dont understand, any suggestion friends?
    looking forward eagerly….
