Activity › Forums › Apple Final Cut Pro Legacy › stuttered playback?
  • stuttered playback?
    Posted by Tad Newberry on February 26, 2006 at 11:53 am
    i had a few clips in my timline that when viewed in the canvas, sort of stuttered along. this seemed to be the same whether they were 8-bit or DV clips captured from my 1800 BetaSP deck. then when i made the DVD, the beginning stuttered a bit (though on different clips than the ones that had stuttered in the timeline) on one DVD player, and was out of sync and jumped around and was blocky on another player. any ideas? corrupted video on the hard drive? trash the prefs?
    thanks…
    thanks for helping out a bonehead,
    jtn
  • Bouncing Account needs new email address
    February 26, 2006 at 1:55 pm
    A slow hard drive (external FireWire drives can sometimes be slow, or using the “System Disk” on the Mac for capturing can cause problems.
    You might have a corrupt capture file or two, if the problem persists after you try the following, try to recapture the “bad” clips.
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
