Activity Forums Apple Final Cut Pro Legacy Stutter When Applying Movement to Livetype
  • Stutter When Applying Movement to Livetype
    Posted by Springer on April 7, 2005 at 10:39 pm
    I’m having problems when putting movement to Livetype graphics imported to FCP. When I set up and do, say, a simple slide onto the screen from left to right of a Livetype graphic, the graphic stutters or ‘jumps’ during the movement. The result is unwatchable…Can anyone tell me what I’m doing wrong? I’m watching the output on an NTSC video monitor. Thanks…!
    Mark Maness replied 21 years, 5 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    April 7, 2005 at 11:25 pm
    Are you rendering in FCP before checking?
  • Springer
    April 8, 2005 at 12:32 am
    Yes, I’m rendering before checking…this has been an intermittent problem for us in the past…the font I’m using is relatively large, which is the only thing different about this project. Could that be part of the problem? I must admit I am stumped..(but I’m also a fairly new user)….
  • Mark Maness
    April 11, 2005 at 6:51 pm
    Check your poroject setting in LiveType, they need to match the project settings in FCP.
    _______________________________
    Wayne Carey
    Strike King Media
