Activity Forums Adobe Premiere Pro stutter playback on premiere cs5?
  • stutter playback on premiere cs5?
    Posted by Josh Phoenix on April 4, 2012 at 10:45 pm
    Im running a very fast machine and I am experiencing lag in my playback and wondering if this is normal? Im running sandy bridge E 12 core with gtx580. I only have 16 gbs ram but I dont see it even touching 8. My project seems to stutter in the playback after about 30 seconds of the timeline. I have a 10,000 rpm drive as my scratch and a 512 ssd for the application itself. wtf?
    Josh Phoenix replied 14 years, 5 months ago 4 Members · 6 Replies
  • Chris Borjis
    April 4, 2012 at 11:20 pm
    what kind of footage?
    A single SD video layer sequence might playback fine
    with a single drive.
    You need at least a RAID Zero
    setup to keep playback smooth with HD multi-layer editing.
    have you tried setting the preview to 1/4 res?
  • Josh Phoenix
    April 4, 2012 at 11:24 pm
    I’m editing the Native 5dmk11 files(I think there h264)
    Im not even using multiple layers, at least not in the same playback. I have tried lowering it to half. Dang, I cant believe this system with one of the fastest cuda cards cant even playback hd video smooth. Imovie x and avid work just fine…. Premiere has some bugs to work out I think.
  • Tero Ahlfors
    April 5, 2012 at 3:40 am
    Have you upgraded your video card drivers and Premiere? What are your sequence settings? Is the hardware Mercury Playback Engine enabled?
  • Chris Borjis
    April 5, 2012 at 4:45 pm
    Josh, I suspect its highly likely your hard drive is inadequate
    for the task.
    A single drive that spins at 10,000rpm is not enough.
    the amount of throughput you need is just not there.
    I have a RAID 5 and I can playback RED 4k footage
    at 1/4 rez in real time.
    It’s not premiere or your CUDA setup.
    Your trying to move a gallon of water through a cocktail straw in
    2 seconds.
    Get or borrow a Raid drive…thats what will likely fix it.
    Even a lower cost RAID 0 setup will have much higher throughput.
  • Jon Barrie
    April 6, 2012 at 5:02 am
    Hey Josh,
    Sounds like you are trying to playback at Full Playback Quality with effects on it. You want to drop down to 1/2. It only affects the way you watch is back, like an on the fly proxy via the software that eases the taxing weight from the Original media/compressor on the CPU. That’s Mercury at work, on a Software only level. Doing the CUDA Hardware GPU side helps with RT effects. I use a Quadro and it rocks. There’s a reason the GTX cards are cheaper. Gaming cards/drivers not built and tested specifically for Heavy Video work.
    Let us know what happens when you drop the playback to 1/2 and be sure the Hardware is being recognised and used in CUDA GPU Mercury Playback Engine.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Josh Phoenix
    April 7, 2012 at 3:33 am
    Thanks for the replies. I tried dropping it down to a quarter and same thing. I think it is a raid/ hardrive issue. The GTX580 seems to be a great workhorse for me so far and the specs seemed substantially better than the quaddro. I guess its user preference…
