  • Posted by Gunnar Kordestani on June 4, 2007 at 2:14 am
    hi there,
    I want to create the following ‘stuttering effect’:
    frame 00:01 – freeze for 12 frames
    frame 00:13 – freeze for 13 frames
    frame 01:00 – freeze for 12 frames
    frame 01:13 – freeze for 13 frames etc……
    I am using PAL 25 f/s
    I think i should use ‘timeremapping’ and some expression do automate this process, but have no clou how to do this… any propositions out there?
    thx
    Gunnar
    Gunnar Kordestani replied 19 years, 4 months ago 2 Members · 2 Replies
  • Filip Vandueren
    June 4, 2007 at 3:56 am
    So basically what you want is a 2 FPS look, but you don’t want every other freeze to occur in between two fields at time “12.5”.
    So the easiest way without expressions would be to just use a “posterize Time” effect and render without fields.
    If that’s not an option, this works for me:
    Apply timeremapping and give it this expression:
    posterizeTime(25);
    Math.floor(time*2)/2;
  • Gunnar Kordestani
    June 4, 2007 at 4:48 am
    hi Filip,
    yea that’s mor or less what i was looking for thx.
    Gunnar
