Activity Forums Blackmagic Design Stutter and green lines with desktop video 9
  • Stutter and green lines with desktop video 9
    Posted by Peter Magnusson on December 3, 2012 at 10:51 am
    I get monitor problem when i update from Desktop video 8.6 and above. I have had this problem with both OS 10.7 and 10.8. The monitor is stuttering and show fat green line bumping all over the screen. Even when in still mode not playing. All my settings should be OK. I think have tried everything…
    This happens in both FCP7 and Resolve 9.
    Peter Magnusson replied 13 years, 9 months ago 2 Members · 2 Replies
  • Peter Schroeder
    December 11, 2012 at 9:07 am
    i have the same problem, had to go back to 9.5.3.
    did you find a solution ?
    Mac pro 3.1. Decklink HD extreme
    Peter Schroeder
    Director /Editor
    Macpro 2x 3,2 Quadcore , os 10.6.2 FCP 7.01 8GB Blackmagic Decklink HD
  • Peter Magnusson
    December 11, 2012 at 9:16 am
    No, the problem is not solved. I stay with 8.6. Emailed Blackmagic support and got this reply:
    If the problem is only present when you swap to the new driver version i suspect it could be an incompatibility either with your machine or there has been a revision in the decklink boards them selves.
    If this is is the case i feel it would be best to uninstall the new driver and stay on the version that works ok.
    I am sorry about this but i hope you find the information useful.
    Regards,
    Peter Walker
    Technical Support Consultant EMEA
