Activity › Forums › VEGAS Pro › Stutter after render – makes no sense
  • Stutter after render – makes no sense
    Posted by Peter Frank on May 20, 2017 at 8:37 pm
    Using Vegas Pro 13
    Original file plays smooth as silk.
    For Project Properties, I use “Match MEdia Settings” and select my original file.
    To render, I use “Match project settings” to find templates that (I assume) match my project settings.
    I’ve tried AVC and AVI = varying degrees of not-smooth.
    I’ve tried everything set to “best”; two-pass = varying degrees of not-smooth.
    Here’s my original file:
    Format: AVC
    Format/Info: Advanced Video Codec
    File size: 23.8 GiB
    Overall bit rate mode: Variable
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile: High@L4.1
    Format settings, CABAC: Yes
    Format settings, ReFrames: 4 frames
    Format settings, GOP : M=3, N=15
    Bit rate mode : Variable
    Maximum bit rate : 40.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 (24000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    What could be the culprit here? Even an AVI render isn’t smooth?
    Driving me nuts.
    Thanks in advance, for any advice!
    Peter Frank replied 9 years, 4 months ago 2 Members · 5 Replies
  • Aaron Star
    May 21, 2017 at 6:00 pm
    What generated the source file?
  • Peter Frank
    May 21, 2017 at 9:42 pm
    I ripped a blu-ray to MKV, to edit it.
    I demuxed the MKV to separate the video and audio files, but Vegas doesn’t like the MP4 that came from it.
    I used VLC media player to “convert” to MP4, as for some reason Vegas accepts it.
    The MediaInfo above is from the file VLC produced.
    I noticed something else.
    When I click on the MP4 (from VLC) in Vegas, it reports the properties are 1920x1080x12
    When I told it to “Match Project Settings to Media”, it sets the project settings to 1920x1080x32
    I’ve researched that a little, and I get it may be nothing, but I don’t really understand it and it’s one of the few differences I’ve noticed between the AVCs Vegas renders (all with stutter) and the VLC file (which plays perfectly).
    Also, I noticed the VLC file is actually 1920×1088, though Vegas says it’s 1920×1080.
    I assume that’s not causing stutter, but I’m not sure.
    Any ideas?
  • Peter Frank
    May 25, 2017 at 3:26 pm
    Aaron do either of the two things above play a role, in your experience?
  • Aaron Star
    May 25, 2017 at 6:33 pm
    I do not want to comment on ripped DVD material. I use Vegas to create original content.
  • Peter Frank
    May 25, 2017 at 7:30 pm
    Aaron I understand and respect that position completely, though my project does not involve a movie.
    I’ve sung barbershop quartet harmony for more than 25 years. In that time, I’ve amassed a number of show and competition videos of my groups (all amateur), so I’m compiling them into one library of videos – cleaning up the video and audio as best I can, etc., with the intent to give them as gifts to my friends with whom I’ve sung.
    For one particular local contest, a barbershopper shot the event on HD camera, then published a blu-ray of the event for the participants.
    To be honest, I’ve worked around it, however it required another conversion, which drives me nuts.
    If you understand my project better, and are willing to share any insight, I’d still be grateful.
    If no, again I completely respect your views.
