Activity Forums Adobe After Effects stupid question – ram preview key commands on a laptop
  • stupid question – ram preview key commands on a laptop
    Posted by Chet Wesley on October 25, 2008 at 8:38 pm
    Hi. I am using a mac book pro that doesn’t have a numerical keyboard. Is there still a way to use key commands for RAM previews.
    I am particularly missing the command to get it to preview just every other frame – that one isn’t even available in the menu.
    Ben Lindsey replied 17 years, 11 months ago 2 Members · 3 Replies
  • Ben Lindsey
    October 27, 2008 at 3:26 am
    yep the command is fn+spacebar… yo may have to hit the spacebar a second time to play it or it will load your entire comp even if you set in and out points
  • Chet Wesley
    October 27, 2008 at 3:39 am
    Thank you sir.
    That doesn’t seem to play the audio though for some reason.
  • Ben Lindsey
    October 27, 2008 at 6:24 am
    if you hit spacebar after it finishes it will play with the audio…i really hate it because im use to it automatically playing as well.When im showing it to clients and ram preview and i tap the spacebar over and over because it suppose to play with sound after ram previewing.
