Activity › Forums › Adobe Premiere Pro › Stupid Question – But an answer would improve my workflow
  • Stupid Question – But an answer would improve my workflow
    Posted by Kevin Hill on May 23, 2012 at 10:00 pm
    New Premiere Pro user here.
    When I hit “f” in Premiere Pro CS6, a frame of the video track my mouse is over pops up in the viewer that is to the left of the main viewer window. (I’m sorry, I don’t know their names.)
    Is there a way to make this panel display the video WITH all of the video effects on it? Right now, the frame pops up without any video effects, which makes this less than ideal for color grading one clip to match another.
    Thanks for bearing with me!
    Calgary Wedding Videographer / Cinematographer
    snapweddings.ca
    Kevin Hill replied 14 years, 4 months ago 3 Members · 5 Replies
  • Tom Daigon
    May 23, 2012 at 10:17 pm
    You are match framing to the original clip in the Source window.
    If you want to see the effects related to the clip on the timeline, double click the clip on the timeline and then go to the effects tab in the source window.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Kevin Hill
    May 23, 2012 at 10:23 pm
    LOL
    Thanks for that! Now it seems so obvious! Appreciate you taking the time to help!
    snapweddings.ca
  • Jon Barrie
    May 23, 2012 at 10:27 pm
    Unlike FCP, Master Clips don’t hold effects, only the instances used in a sequence, so doing a match frame will bring the master clip into the source on the matched frame from the edit.
    To perform a grade whereby you want to do a comparative of shot X, you are grading, to shot Y you already have graded, there is a panel in the Window Menu called “Reference Monitor”. Open this and be sure to ungang the timeline from it so then you can have the playhead of this it on your reference shot (from the timeline, which shows the effects on the instance and then have the sequence/program monitor on the shot you want to grade.
    To show the effects of a clip, there is no need to double click a clip (like FCP), simply select it in the sequence and the clips properties and effects will populate the Effect Controls Panel. Manipulate your effects as you desire.
    Understanding the desired outcome helps to find the Adobe way to complete the same tasks. 🙂
    Cheers JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Tom Daigon
    May 23, 2012 at 10:32 pm
    Glad to help, Kevin.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.7.3
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Kevin Hill
    May 29, 2012 at 8:50 am
    Jon, Thank you so much. Your response solved my confusion. Now grading is so much easier!
    Thanks again for taking the time to help!
    Kevin
    snapweddings.ca
