Activity Forums Apple Final Cut Pro Legacy Stupid Question about ProRes 422
  • Stupid Question about ProRes 422
    Posted by Lynette Gilbert on November 30, 2012 at 3:20 pm
    I work with a lot of different mp4 files – I always convert them to ProRes 422 before working with them in FC.
    Every once in a while, though, I have the hardest time editing them. For instance, if I drag the ends of the clip, I can see the video in the canvas, but if I try to just play or scrub through, it’s just black. If I put it into the viewer, I can’t see it at all when I play. I always use the same settings, so why does this happen sometimes? (And by “sometimes”, I mean maybe 1% of the files. It doesn’t happen very often.)
    I wish I had an example right now, but I can’t remember the last file that did this. I just happened to be thinking about it as I converted some h.264 files (which converted beautifully) and thought I’d post before I forgot again.
    Lynette
    Lynette Gilbert replied 13 years, 9 months ago 1 Member · 1 Reply
  • Lynette Gilbert
    November 30, 2012 at 4:18 pm
    Hmm. Could be simple user error. I usually create a new folder called “Converted Files” and save it right to there, then import the folder, but I’m not certainly not above stupid mistakes.
    Lynette
