Activity Forums Storage & Archiving Stupid question….
  • Stupid question….
    Posted by Eric Santiago on March 19, 2020 at 3:59 pm
    I’ve been asked if remote access is better than having access to our file server at work.
    They want the graphics team to work from home.
    I have informed them that access to the file server is best.
    But for some reason, the IT dept is trying to set-up each Mac for remote access.
    I do this all the time using VMWare on Windows.
    I can’t imagine trying to run After Effects via remote access 😛
    Is this nuts or what?
    Nathaniel Cooper replied 6 years, 5 months ago 2 Members · 1 Reply
  • Nathaniel Cooper
    March 19, 2020 at 4:40 pm
    Yes, having local access will give you more performance than remote. If the IT team is setting up a VPN, I’d say let them go for it, there’s not a reason not to. For opening and working on an AE project, it will depend on what is in the project/how big it is/connection speed at home & the office.
    Smaller AE projects will buffer in RAM and could be seamless, but that is for very basic stuff. Likely anything they are working on would need to be copied, then worked from locally. I’d have them set up the VPN then try.
    ProMAX customers are all facing the same challenge. We put together a Remote Video Editing Workflows: Your Options blog. Given this is written for ProMAX customers/products, however most of the advice applies to most scenarios. I’d very much recommend the 40 min webinar reply at the bottom. Our VP of engineering really broke down a TON of good info for anyone that needs to understand some of the upsides and downsides of remote options.
    Good luck!
    Nathaniel Cooper
    nathaniel@promax.com
