Activity Forums Blackmagic Design Stupid Question
  • Stupid Question
    Posted by Rich Harrison on November 15, 2005 at 5:36 pm
    Hiya,
    Okay, so this is probably a very stupid question but here goes; Can a clip digitised with a Blackmagic capture card be used / worked on a system with a Kona 2 card?
    Rich
    Luke Maslen replied 20 years, 9 months ago 4 Members · 5 Replies
  • Kaspar Kallas
    November 15, 2005 at 5:50 pm
    Yes
    -Kaspar
  • Rich Harrison
    November 15, 2005 at 5:57 pm
    What problems, if any are likely to arise from doing this?
    Rich
    Hiya,
  • Luke Maslen
    November 16, 2005 at 6:20 am
    Hi Rex,
    Both cards use the Apple codecs for capture and playback so there should be no problems moving files between systems.
    Regards,
    Luke Maslen
    Blackmagic Design
  • David Mallin
    November 16, 2005 at 10:20 pm
    Luke,
    That’s only true for users using FCP5 / Tiger, correct?
    David
    _______________
    David Mallin
    Cloudchaser Films LLC
    Santa Monica / San Francisco
  • Luke Maslen
    November 17, 2005 at 4:21 am
    Hi David,
    Yes and no.
    In standard definition, we’ve used the Apple codecs for capture (and playback) since Final Cut Pro 4.0 was released. The Blackmagic codecs were still used in HD through to Final Cut Pro HD 4.5.
    Apple introduced a HD color space in the codecs included with Final Cut Pro HD 5.0. As a result, we now use Apple codecs in SD & HD. An exception is with 4:4:4 HD material. Apple don’t yet have a colorspace in their codecs for 4:4:4 so we still use our own for that.
    So the short version of this is that we use the Apple codecs in SD and HD for all 4:2:2 material in Final Cut Pro HD 5.0 which makes it easy to share with users who are not using DeckLink systems.
    Regards,
    Luke Maslen
    Blackmagic Design
