Activity Forums Adobe After Effects stupid little question
  • stupid little question
    Posted by Accountclosedduetonorealnameused on January 24, 2007 at 6:53 pm
    I can press the “V” ket to drag a layer anound in the comp window.
    If I hold down the “W” key I can rotate, then when I relase it goes back to the repo “V” key function, got this, very handy
    the question, is there a key, or key combo to scale an image in the comp window?
    I seem to remember doing just this. (I do not like to use the bounding box edges to scale)
    thanks!
    Tony Kloiber replied 19 years, 7 months ago 2 Members · 1 Reply
  • Tony Kloiber
    January 24, 2007 at 8:46 pm
    Well your right it is a stupid little question. How about an annoying answer? Both the functions you describe require you to drag around in the comp window so what do you have against dragging to scale?
    If you mean to scale the layer (i.e. 100,100 to 90,90) You could just type it in the scale parameter. If you want to zoom the image in the comp window on the mac you hold the command key and press (+) or (-) key.
    Ok maybe not so stupid little question.
    TonyTony
