Activity › Forums › Blackmagic Design › Studio Videohub – Can someone confirm the routing of the outputs
Posted by Shaun Roemich on December 1, 2011 at 11:56 pmThe Studio Videohub until very recently was marketed as 16 x 32 router but is now being marketed as a 16 input, 32 output router.
Can I assume that the outputs are not INDIVIDUALLY routable and in fact route in pairs?
So more like a 16 x 16 x 2 router.
Hope this makes sense. Trying to decide on the 16 x 16 or the 40 x 40 if the Studio is NOT a true 16 x 32.
Big Dog – Technical Director – Switcher
Road Dog Media – Vancouver, BC Canada
roaddogmedia@gmail.comShaun Roemich replied 14 years, 9 months ago 4 Members · 7 Replies -
Sam Cole
December 2, 2011 at 12:38 amit is 16 input and 32 output.
The design is based on having eg 16 rooms that each feed the router and 2 feeds back to each room as 1 for input to the NLE and 1 for the room monitor.Sam Cole
On line Mastering Facility
FCP, Avid, Adobe
Sydney, Australia -
Bob Zelin
December 2, 2011 at 4:31 amthis is a true 16×32 router. You can assign any of the 16 inputs to any of the 32 outputs independently. Output 1 and Output 17 (the “matching pair” for the first group) are completely independent of each other and you can assign anything you want to output 1 and anything you want to output 17. This goes all the way up to output 16 and output 32 – they are totally independent of each other.
Bob Zelin
Shaun Roemich
December 2, 2011 at 10:25 pmThanks Bob. I ASSUME you are verifying this by actually having used the device and not just on literature?
I’ll be ordering mine sight unseen so I NEED to make sure I get this right.
roaddogmedia@gmail.com -
David Chai
December 3, 2011 at 6:46 amYes, it is 16×32. Having used both video hub studio and broadcast videohub which has 72×144 – worked flawlessly for almost a year now.
David Chai
Writer . Director
http://www.davidchai.com
dc@davidchai.com
212 363 0159 -
Shaun Roemich
December 3, 2011 at 7:47 pmOnce again, MUCH appreciated! Probably order mine in January when I have money again!
Bob Zelin
December 4, 2011 at 4:52 pmhi shaun,
yes – I install Blackmagic routers on a regular basis, and this is from my first hand experience, not just reading the manual. I usually use a cheap bare bones Mac Mini to control the router. These routers will not work “stand alone” – they need to be on a network – so that is your “hidden cost”.Bob Zelin
Shaun Roemich
December 4, 2011 at 5:08 pmAgain Bob, thanks.
I was under the impression that one could “log in” to the router to make changes and then disconnect the computer (possibly a laptop in my application) and that the network connection to the control computer doesn’t need to be constant. Is that correct?
I will be using it for routing sources in and out of my ATEM based multicam system and once the show is set up, historically I don’t need to make changes until the next show.
Appreciate your learned input! Thanks.
