Studio RGB to Computer?
Whenever I take one of my MP4 files and open them in vegas to do some cleanup, the resulting video has a lot brighter output than the source.
Original:
vlc-original.pngOutput from Vegas:
vlc-after_vegas.pngYou can see how on the Vegas output you can see a clear difference between the black bars on top and bottom where the original the black levels were pure black and bars weren’t seen.
My final destination due to using Xbox is a high bitrate WMV file but am using vegas to use a clean video filter and then use Microsoft Expressions for the final encode.
I encode with AVI uncompressed in Vegas as the output format. Taking the original video and converting with Expression Encoder directly looks great, just when I use Vegas get the lightening.
Final display is on a plasma screen thru my media center system. No plan to put on BluRay or DVD.
Should I be applying the Levels Studio RGB to Computer RGB setting for the final output? Seems like it may return things to the source levels but not sure.
Thoughts?
Thanks.
JR
