Activity Forums VEGAS Pro Studio 8 Platinum
  • Studio 8 Platinum
    Posted by Steve Littler on January 28, 2008 at 10:54 pm
    Does Studio 8 Platinum come with the ability to import AVI files that have MJPEG codec like you would shoot with your still digital camera?
    (My regular Studio 8 version did not.)
    Bruce Brent replied 18 years, 7 months ago 3 Members · 9 Replies
  • 9 Replies
  • Douglas Spotted eagle
    January 28, 2008 at 10:59 pm
    I don’t believe it does. However, you can download several free MJPEG codecs that Vegas Platinum will use to decode.
    Curious…I wonder if installing the demo of Vegas Pro will allow you to access the decoder? I’d imagine it would.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Steve Littler
    January 28, 2008 at 11:16 pm
    I bought the Main Concept MJPEG codec for $21.00 and installed it. But when I render out a QuickTime file, it is very slow and creates an extra large file that has jumpy playback.
    I also own the AVS4YOU video editor which costs about the same as Vegas and it didn’t need this codec and it made much smaller files with smooth playback.
    I just bought Vegas because I thought it would give me more options for more professional work.
    I basically want to make quick files to put on the Web (YouTube etc) or CDs or import to Flash to publish to the Web.
    January 28, 2008 at 11:33 pm
    That would be a problem related to the type of file you’re rendering TO, not the type of file from which you’re rendering/source material.
    If your source material isn’t jerky/jumpy, neither should the render be.
    Render to the MP4/iPod template in Vegas for best generic results for loading up to YouTube.
    VASST
  • Steve Littler
    January 29, 2008 at 12:07 am
    Thanks for the tip for YouTube.
    But I still need to burn a bunch of these files on CD. They are dance files of various dancer friends. Also, the teacher prefers QT files for his Flash Programmer import into Flash to put on to his Web site.
    (The AVI MJPEG source files are quite smooth at 30 frames per second shot at 640×480 on a Canon PowerShot SD630 Digital Elph. And they play fine by themselves on a computer.)
    So I want to find out if the problem is inherent in Vegas Studio, or is it just my installation/setup somehow that it goofy? (I’m able to get good results in my ASV4YOU editor but it doesn’t have the extra tracks that Vegas has.)
    Many thanks!
    January 29, 2008 at 12:31 am
    Chances are that you’re rendering to Quicktime uncompressed, based on your earlier explanation. the problem isn’t your system, nor Vegas, it’s pilot error.
    You need to use the Custom Tab in the Quicktime options to create a Quicktime DV file.
    VASST
  • Steve Littler
    January 29, 2008 at 3:35 am
    Ok, I am willing to fix pilot error.
    So I went in to check Custom settings and the default settings are:
    Project tab:
    Video rendering quality: Good
    Video tab:
    Frame rate: 29.970 (NYSC)
    Field order: Non (progressive scan)
    Pixel aspect ratio: 0.909
    Video format: None
    Compressed depth: 32 bpp color
    Quality: 50%
    Audio tab:
    Audio format: Uncompressed
    Sample rate (Hz): 44,100
    Bit depth 16
    Channels: Stereo
    I rendered 10 seconds of video to a QT file and it took 1 minute 33 seconds and gave me a file 372 MB in size that plays back very jumpy.
    Any suggestions for this pilot to fix.
    Many thanks!
    Steve
    January 29, 2008 at 3:57 am
    Fix as I’ve listed below:
    Video tab:
    Choose the Frame Size of DV/NTSC
    Frame rate: 29.970 (NTSC)
    Video format: DV
    Compressed depth: 24 bpp color
    Quality: 100%
    that should fix you up.
    VASST
  • Steve Littler
    January 29, 2008 at 4:19 am
    Ok, I did that,
    but my Web Format didn’t have a DV only choice, the the closest thing was DV/DVCPRO-NTSC, so I put that.
    and it rendered in 48 seconds and the file was 38 MB. It plays smoothly now but the quality was not too good. A lot of pixelation and artifacts and wavy lines.
    Any other suggestions?
    Many thanks!
    Steve
  • Bruce Brent
    January 29, 2008 at 11:20 pm
    Steve, what works for me is on your computer….Windows Movie Maker.
    Import your camera’s file and drag it to the timeline. Then, go to Finish Movie and save it as a DV (AVI) file. Then, you can take it to Vegas and edit and save/burn.
    Enjoy!
