Activity Forums Adobe After Effects Stuck on “rendering 2 frames” for ages
  • Stuck on “rendering 2 frames” for ages
    Posted by Olly Lawer on May 13, 2014 at 11:52 am
    We’ve got MP turned on. Keeps getting stuck on “rendering 2 frames” for ages…then finally ploughs through the animation.
    The Mac Pro used to do this, but since we got a thunderbolt SSD, it is better. Funny thing is, the PC has two internal SSDs and one is solely for AE renders!
    Any ideas?
    Olly Lawer
    Olly Lawer replied 12 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Olly Lawer
    May 13, 2014 at 4:35 pm
    Ruled out all apart from the top one (happens no matter the project or effects).
    What do you mean by bad settings?
    Olly Lawer
  • Olly Lawer
    May 13, 2014 at 4:52 pm
    16 core machine. Using 16 cores for AE on 4GB each. 16 virtual cores reserved for other applications and 10gig of RAM I believe. Can’t check as rendering, but it’s very similar if not that.
    Olly Lawer
  • Roland R. kahlenberg
    May 14, 2014 at 10:44 pm
    Olly, your cache may be full. Empty or purge your cache and see if this helps. Please report back.
    Cheers
    RoRK
    Gaudy Teaser Promo for an upcoming AE Type Gizmo.
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
  • Olly Lawer
    May 15, 2014 at 6:31 am
    Thanks, but I wish it was that simple. We tried this first.
    Olly Lawer
  • Walter Soyka
    May 15, 2014 at 3:17 pm
    If you open the Task Manager (Ctrl+Shift+Esc) and watch it while you start the Ae render, what do you see? I’d be particularly interested in the Processes tab (how many instances of AfterFX.exe, how much RAM & CPU usage).
    I’d also like to see the Resource Monitor’s Disk tab. (Ctrl+Shift+Esc to open Task Manager, Performance tab, Resource Monitor button).
    Walter Soyka
  • James Nielson
    May 27, 2014 at 10:30 pm
    Sounds similar to my glitch: I’ve got a main comp in which I’m assembling sections of an animation. I WAS sending each of those sub-comps to render individually, but AE recently started taking forever to load/render them. BUT when I render them out from the main comp, it seems to work fine. Not ideal, but if it gets ya through the job…
    James Nielson
    http://www.x-dissolve.net
  • Olly Lawer
    June 13, 2014 at 4:12 pm
    Took a couple of screen grabs finally:
    Stuck on 2 frames for 5 minutes:
    After it started:
    Any idea?
    Olly Lawer
